Neal W
- Jan 6, 2015
I got my guide rail square from tso products yesterday and was tinkering with it. Other people had commented about there being two threaded holes on the square. Hans eluded to something being on the works so I thought I would try some West Virginia engineering.
I Have a section of incra t-track plus. And also the components of the rip dogs parallel guides. The pre drilled holes in the incra track don't line up. They were also a little too small for the screws which fit the little t-nuts. So I drilled an extra hole and enlarged one of the pre drilled holes.
Using the mnobs from the rip dogs set and the t-nuts I was able to screw the track to the tso square.
It seemed to work pretty well, other than making the guide rail want to tip up of the work piece. The weight of the saw holds it down.
The only drawback I see so far the set width of cut is limited to about 16 3/4". Otherwise it is a way to consistently set for a width and a square cut.
