about Power consumption and Transformer 110v
I don't think so. I use a 3.3KVa with my CT 22 using all my festools, CMS w/ TS 75, OF2200, plus Kapex, TS55 and various sanders and domino etc.
Its the continuous rating and the KVa that affects performance IMO.
Note Im not a sparky (electrical guy) Im some yank who moved to the UK with his 110V festools.
This is what I use in my shop.
Agreed with above comments.
CT midi draws 1200W/110V which is nigh on 11A on its own (don't know power factor). Add in the saw/router and you are way over the transformers limit.
Also watch out for the rating of the transformer. The one mentioned is 1.2kVA intermittent use only and drops to 600VA continuous, no duty cycle is quoted on the Screwfix site.
Simon.
even a 5kva would be better for the of2200
when using the of2200 in the cms with ctl26 i have overheated/tripped a 3.3kva running rail&style bit
I am confused.
I hought that the UK is 220v, except for job sites.
Why would one need 110v to 220v ?
UK is nominal 230V.
Tranny is a step down from 230V to 110V.
And your right most commercial sites do require 110V.
Simon.
