Abrasive Systainer , LS130 RTS400
semenza
Festool Moderator
Festool Moderator
         This is also posted in the LS 130 review. I have added updated pics showing the official labels now in place ( yeah, I know I am off the deep end).
    I thought it would be good to add this in to the LS 130 review. Below are pics of my pad/abrasive systainer for the LS130. I got the idea from Ned Young.  We both used a Systainer  - II. His has the real Tanos deviders (NAINA).  But otherwise basically the same.
        I was interested in the systainer for 80 x 130 sheets also  But it only has six compartments. I wanted room for possibly more grits and also the pads for the LS130 Sander.    I made the deviders from 1/4" plywood. They are strips with slots cut just past the halfway point so that they will slip together when reversed to each other. I went with 16 evenly sized compartments. I did not make them adjustable they are glued together in the slots so that there is no wiggling around or coming apart. I really didn't think I would need to adjust them anyway.
       The sizes for the plywood pieces are-    All are 4 1/2" tall
                                                             1    15 1/8"
                                                             2    14 15/16"
                                                             1    10 7/16"
                                                             2    10  11/16"
                         The lengths may vary depending on exactly were you want to place divisions in the systainer.
srs
      Pretty sure the ends of the pieces are cut at about  2- 3 degree angle to better match the slope in the side of the Systainer.  It has been modified to fit in a T-Loc now so I can't check much on the original parts anymore.
