wptski
- Mar 7, 2016
I have a brand new Bosch CM10GD 10-Inch Dual Bevel Glide Miter Saw, my first.
I went through the setup checks and all checked right on the money but it cut off square at least 0.5 degree. Most if not all procedures for checking the bevel setting is on the left side looking from the front. Checked on the right and it's off square in the direction it's cutting off and by the same amount.
Adjusting the bevel is a PITA, first using a solid square(a Starrette #20 3" belonging to my father that is +80 years old) and finally a Wixey WR-400 3" which worked nice for that. It cuts square now but where's the problem, blade or the base??
I had a Diablo 10" 80T finish blade coming so I put that on today and checked for squareness first, it showed the same error on the left side so it has to be something in the base on the left side. This blade cuts super smooth and square as well.
I also installed a Oshlun laser washer.
Just what kind of accuracy at best can be expected from a miter saw?
