GarryMartin
- Jun 11, 2011
For the money it costs, the CS 70 fence should be better than it is. It doesn't travel easily along the grooves and there's a very specific approach to tightening/adjusting to ensure it remains square. When used with the MFT/3-VL and MFT/3, you'll need to figure out a way to add your own rule and adjust it according to the plate position.
The "standard" fence uses the same protractor head that you get with your MFT/3, so it's usable in the MFT/3-VL and MFT/3 profiles from both the front and the sides (and the back if need be!)
If you square the MFT/3 accurately to the plate in the MFT/3-VL, then you can certainly come up with a "shop made" fence. I considered using an Original Incra Jig to put something together before using the Incra LS Positioner with the Precision Dogs Precision Plate.
