cliffp
- Jun 22, 2012
I am planning to make an AV unit. It will be 6' wide, 2' deep and 18" high. I am planning to have two vertical partitions to create 3 bays and 2 shelves within each bay. The idea is to place one item of hifi or av equipment in each slot. I wasn't planning to have any doors. I was thinking of using white oak as its relatively cheap. My question is, would I be advised to use veneered mdf with a solid face frame, in which case would it be better to mitre the top, bottom and sides (I have a domino so I could do this quite easily) or should I use an edging strip and butt joint the top onto the sides and the sides onto the bottom. I am afraid that edging strip might look a bit cheap. Maybe it would be better to glue a wider piece of solid oak onto the ends of the top and bottom rather than use edging strip?
Alternatively, I am not completely against the idea of using solid oak for the whole thing if it would look much better. I just don't have the experience to know how much better solid wood looks than veneered mdf.
Finally, I can't decide what edge treatment, if any, to use on the face frame (or front edge if using solid wood). The style of the room is contemporary.
Any advice would be gratefully received!
