Cheese
- Jan 16, 2015
It's been my experience that each blade manufacturer, in this case Leitz, tend to use the same amount of carbide overhang when manufacturing saw blades of different kerf widths. So the thickness of the blade plate changes, which then changes the kerf thickness but not the amount of carbide overhang.
Thus, there is no need to use spacers if you stick with the same blade manufacturer.
Pretty easy to check...measure each blade kerf thickness and subtract the blade plate thickness and divide by 2. That's the amount of carbide overhang on each blade. If the overhang is the same there's no need to shim the blade.
For Forrest blades carbide overhang is .009", Mafell blades run .010" and Leitz runs .012".
