Just curious to see what happens if I stick HTML character entity references in a post.
[tr][td]
If this works, you should see 2 copies of the symbol named in the lefthand column on each line.
Doesn't look promising from the preview, but I'll post it anyway.
[Added] OK, SMF is definitely not parsing the posts as HTML.
As far as I know, this is the first use of SMF's table code on this board. It works.
PHP doesn't work, no surprise since the post isn't being parsed as a web page. Probably a good thing. That'd be a huge security flaw.
I had intended to delete the post after the test, but I'll leave it around FYI.
Euro | € | € |
Pound | £ | £ |
Degree sign | ° | ° |
