Dane
- Jan 27, 2008
So after checking out the new Festool Parallel Guide, I decided that it was a bit over engineered and fussy for my needs. I realize that no matter how easy they try to make it, I am never going to rip narrow strips with the guide rail in any great numbers my little dewalt table saw just does that too well. Plus I can use that other parralell guide thing that attaches to the saw for that. So what I really needed was a way to repeatably do rips from say, 12" to 30". I was banging around Lowes the other day and came across these folding, adjustable drywall squares and thought I would give them a shot. They adjust to 48", but I realized that never in my career have I needed to repeatably rip 48", so I chopped about 16" off of the guides to reduce the weight. You could certainly leave that 16" on and it would work just as well, but be a bit heavier and more of a dangle on the narrower rips. I have built two cabinets with this setup, and so far have had no noticeable variations in width of any of my cut pieces. I checked those square with my most accurate square and they are pretty good. Certainly good enough for this operation which is really just trying to keep them parallel to each other so that you don't get deviations in the width due to the guide running at an angle. I am showing two different clamping methods, the Festool Clamps and the quick squeeze clamps. The squeeze clamps are much easier to use and even with the jig set to its lowest point, and then having about 25" of hang off the workpiece, they keep it in place. Plus they take no time to attach.
Here's the set up:
Make your mark on the first workpiece, place the rail on the mark and adjust the square. [attachimg=1]
Set the second square to the first:[attachimg=2]
Clamp the squares to the work, place rail, cut, repeat.[attachimg=3][attachimg=4]
The advantages to this system to the Festool guide as I see it are: Cheap, about 50.00 including two clamps. Guide are supported by the work and the clamps, no weird tables to build or cobbled together supports. You can use it on any width material, I have ripped 1/4" ply with no issue. Fast, once you get it set, which takes about a minute, resetting for subsequent rips take about 10 seconds.
Here's the set up:
