- Oct 16, 2015
This is the one behind the gray desk for the other post.
The raw area will be laminated in the field after partial reassembly. That front cap unbolts from inside and part of that upper riser unit comes off too. This will allow the unit to fit through the doorway while laying on it's face. It is only 30" high with that removed, but 37" wide as it stands upright. Once it is in place and back together, they will laminate that section, covering the joint, making it seamless. Then the cap can go back.
