Any one use the SIPO Dominoes?
grobin
I am thinking of making a couple tables and some shelves for my deck.  Has any one used the SIPO and how well do they work?
I used them on a handrail system last year.  They are dominoes, they worked great, but it is too early to say if they last or not.  My feeling is that they gave superior placement at glue up and that if my glue does it's job them the domino will be fine.
I used them about 2 years ago to make a planter box out of some old cedar fence pickets. I actually made it using no glue, sort of a puzzle.
The Dominos are in a lot better shape than the rest of it, though it is all still quite fine.
Thanks a bunch guys that's exactly what I wanted to know!  Now I can look seriously at an outdoor project.  (I live at 9500' in Co; the sun is very strong and the humidity varies from 5% to around 30% mostly around
G':
As I think you already know, I live in Austin. the humidity here varies from about 15 percent (though rare) to about 99 percent. The temp' varies from about 20 degrees to about 115 degrees. It isn't a casual test for outdoor wooden objects. I think you'll be fine with the sipo's.
In June of 2008 we built a set of cabinets for a patio kitchen for a client. That was the first time I used Sipo Dominoes, 5mm.
Those Sipo Dominoes have stood up very well. The client and their designer were so pleased with the job they have referred many other outdoor cabinet projects to us. Perhaps there were other ways I could have joined the parts. Prior to the arrival of the Domino in the USA I avoid building outdoor cabinets.
Perhaps the Beech Dominoes would have worked. I never experimented with them outdoors. True, 5mm Sipo Dominoes are slightly more than twice the unit price of Beech. Fortunately a lot of Dominoes fit in a small space, so I stock a lot of both kinds. Perhaps I am over-doing storage, but as soon as I open a factory container, I put those Dominoes into ziplock plastic bags to keep them fresh.
Yet more comfort factor.  Hopefully the UV resistant top coat will stand up.
We built the first of those outdoor cabinet jobs from birch marine-grade 19mm plywood. The finish was applied by the painting contractor on that job. They used a marine paint that is suppose to resist UV. The designer is happy enough with the performance of that paint it was been specified on all the subsequent outdoor cabinets we have built.
grobin said:
Do you know what it was?
I have put in calls to the painting contractor and the designer in an attempt to find the brand and style of the marine paint. The moment I get that information I will share it. My friend who sells a lot of scenic paint told me boat paint is expensive and therefore he does not sell any. Well, Burbank is along ways from the ocean. Unfortunately I know nobody in the boat business.
Thanks guys! My experience with marine paint is from repairing some wood on a Morgan 45, a  Nator Swan and an Intrepid 10m.  I have been across the atlantic three times and around the world once.  But as I live at 9500' and have an average humidity of
