R. Beverly said:
"Table Saw" is a big word. What you have there is, well, junk. You'll spend a ton of time trying to get accurate cuts with it before throwing it (with all that scrap lumber) away and sticking with your Festools. A GOOD table saw with an ACCURATE fence will easily set you back over $1500 - or - you can spend $150 on a 50 year old Contractors Saw and $500 on an Incra TS-LS fence. This combination is excellent for ripping lumber, but still won't match the crosscut accuracy of your TS and MFT.
No matter how nice a tracksaw one has, there are times when cutting narrow piece is better done even on a crap table saw.
But I agree on the idea of upgrading to a different 50 year old saw to add a fence to that.
I used a crapsman for a while.
As far as junk... maybe comparing it to $2000 of 'saw and tracks'... or a different table saw.
But almost any table saw is not junk if one needs a table saw.
The crapsman was not great, but basically the motor spins the blade on all saws., and on all saws the blade cuts the wood.
I cannot fathom how the wood would know that the table saw is crap and come out as scrap?
I admit that the fence was totally 'second hand'. But once you measure and do a test piece and bump it around then it always worked.
I had a sled for it and a massive 2x4 block of maple of the front on the mitre to use to push stock through.
And if one replaced the fence then the fence would be more accurate.
The tilt feature was just truly bad.
The work that came off of it looked fine.
