Looking for some options for 5mm Euro hinge mounting plate screws. Obviously there are plenty of PoziDrive. And a couple square drive. Anyone know of any torx drive? Searches have not yielded any.
Thanks,
Thanks,
Bert Vanderveen said:Don't think there are any. And the reason why is probably this: all adjustment screws on the main brand hinges (Eurostyle, that is) are Pozi, so it makes no sense to use anything else on the 5 mm. (Just my thought process being a designer kicking in here…).
DeformedTree said:Bert Vanderveen said:Don't think there are any. And the reason why is probably this: all adjustment screws on the main brand hinges (Eurostyle, that is) are Pozi, so it makes no sense to use anything else on the 5 mm. (Just my thought process being a designer kicking in here…).
I don't know SRSemenza's reasons, but one "sense" for it could be that torx is much more globally universal. The "problem" with Pozi is it isn't used in other parts of the world, so in the case of the USA, it's hard to find a Pozi screw driver. Walk into any store and the only real chance of finding a Pozi screw driver is a bit driver set that tried to fill it up with everything they can think of. It's also kinda funny since folks here buy lots of IKEA and it's all POZI if it's not allen wrench. I've also noticed a lot of north American electrical switches/receptacles with POZI screws, yet the tool suppliers for electricians don't sell POZI.
In the end, almost no one knows they are POZI and they just proceed with jamming a philips screw driver in there.
Note, I'm not advocating there becoming 2 types for different parts of the world. If Pozi just got phased out globally, I'd be ok with that. At the very least POZI screw drivers need to become more common in the USA.
Now this is the part where SRSemenza gives they're reason and it has nothing to do with what I said [tongue]
....oh, posted while I typed, slightly different reason, does look like he/she is a proper person who uses the correct tool.
Jiggy Joiner said:Can you get Spax over there? There are a lot of companies over here that do international shipping.
GarryMartin said:SPAX don't do a 5mm Euro screw in Torx (or any other head format as far as I know). Seth is looking for these in a Torx head...
Michael Kellough said:To reduce cam-out I try to keep the axis of the driver close to the axis of the screw. If the eccentric chuck isn’t enough an extension helps. The non-magnetic bit holder extensions from Milwaukee and Bosch will also hold Centrotec bits.
kcufstoidi said:Seth I haven't seen them but now use #6 x 12mm torx from Wurth for mounting hinges. If/when needed I just use the 5mm plastic insert. It may a possible solution for you. Unfortunately all pozidrive screws and drivers are not created equal. They are still way better than Phillips though many get easily confused because of the similar look.
SRSemenza said:Yes, this was for a situation where I could not get a good line on the screw.
DeformedTree said:Jiggy Joiner said:Can you get Spax over there? There are a lot of companies over here that do international shipping.
SPAX are here, big box stores sell them. I buy endless amounts of them. But once you get below framing screws, they just do philips, no more torx. And what size they truly are is mystery since they "Americanize" the labeling to inches, and #6, #8 #10, etc so who knows what they actually are.
Bob D. said:
Jiggy Joiner said:DeformedTree said:Jiggy Joiner said:Can you get Spax over there? There are a lot of companies over here that do international shipping.
Fair comment, I notice a few manufacturers nowadays do not give a clear or precise description, of much of what they make.
Many screws I buy have their size in metric and imperial stamped on the boxes, which is a good idea, and should suit most.
We work in millimetres but, when I go and buy screws over the counter, I give imperial sizes, as do many others, and the counter staff seem to register this more quickly.
Jiggy Joiner said:[member=1619]SRSemenza[/member] Look what I found, in China:
https://www.ntfastener.com/product/...XrBnaPfRGPcKFqdvp2jyQoTPIpD35guQaAjyCEALw_wcB
