Anyone used the Fastfix depth-stop control chuck?
erikfsn
I've been thinking of getting one, except I'm not sure if it works that much better than the cheap dimplers.
get a dedicated drill for this job so the bit stops spining when at the correct depth
That's a good description of how this chuck works. It essentially makes your Festool drill into a screw gun, which makes it 5 drills in one if you have the right angle and eccentric chucks already.
It's good for drywall, especially if you're just patching. I think if you're hanging a whole bunch of drywall, you might want to get a dedicated screw gun but you certainly wouldn't have to. I've used it hanging a lot of drywall before. I admit that I'm not a screw gun expert so maybe an expert would go faster with a dedicated screw gun.
It's also good for any task where you want all the screws to be set at the same depth, like a deck.
You can also back screws out with it without having to change the depth setting.
I have used mine quite a bit for hanging drywall, and it is well designed.  The biggest advantage over other adjustable dimplers, at least the ones I have used, it that the depth setting on the Festool really works constantly.  The Festool is also a lot more durable.  If you just have a couple of boards to hang on occasion, it is great.
If you are a little patient - I'm planning a review of the DD-DC drywall chuck.  In a few days I'll get to it.
Regards,
Job
Here's my review of the depth stop chuck (on a C12) with pics: http://www.talkfestool.com/vb/festool-drill-reviews/26-c12-depth-stop-chuck-review.html    I think it's great for hanging a few boards.  The shape makes it work very well for consistently driving screws, even one-handed.   OTOH...
If you are hanging a lot, a dedicated drywall screw gun would be better.   The key issue is speed - the C12's rpms are a bit slow for this kind of work.
Regards,
Dan.
Sorry.   Forrest fixed it.  It works now.  (Thanks Forrest.)
One of the idiosyncrasies of the forum software is that, when it parses a URL, it adds the period to the URL address instead of ignoring it.   I tend to put links at the end of a sentence and then close with space and then a period.  Sometimes I forget the space.  That's when the fun happen.  [crying]
Dan.
