joiner1970
- Jun 13, 2007
Hi if you own the fine adjuster for the guide stop can you please confirm if it came with TWO black thumb screws or just ONE as it shows in all the pictures.
I bought one which came with one but a shop I rang to check said they had two in the packet and someone on here said two also. I tried using one from the router but these are longer and lock the rods before tightening down on the metal angle bracket and when left loose then there is play in the FINE adjuster ???
Basically all I need is confirmation that there should be TWO as now the Festool rep who was in the shop I bought it from is saying you only get ONE.
Cheers for any help.
