Apollo 1050vr question to users
Gregory C
I have just purchased an Apollo 1050vr. The specifications state a max pressure of 9.5 psi. After warmup per the manual, the maximum pressure I see on the digital gauge is about 7.6 - 7.8 psi. This is the pressure with the gun attached and no bleed air flow. When I pull the trigger to bleed air or spray product the pressure drops to 6.0 - 6.2 psi. I talked with Apollo customer service and he said that sounds normal. When I asked where the 9.5 psi figure came from he did not have an answer. To any 1050vr users, is this what you are experiencing with yours? So far it is not an issue since I am spraying thin waterborne coatings at much lower pressures. However, I want to verify all is well while the warranty is still in effect. Thanks.
