Are these bench clamps going to be released in NA?
They look useful. I have seen similar clamps from others available in the States.
Hopefully Festool will make these available here soon. Look like they would make
nice stocking stuffers.  [big grin]
Why yes probably in a couple of years….
All kidding aside, they look nice and very useful.
Hope the come over soon.
Rick.
Neat clamps…however, I do wonder how many times you can use them before they “obround” the MFT holes. They secure themselves to the MFT by being wedged at an angle in the hole.
With all the threads on the FOG about precision dogs, these clamps may mandate both a clamping MFT and a precision dog MFT.
The manner of securing is why I would never use these on my MFT-style workbench.  Here is a video from Dennis (Hooked on Wood) where he is testing similar clamps from Banggood.  The shafts of these clamps are knurled and he tested them in a double-layer plywood top for wear after repeated insertions, but did not test them for damage to single-layer MDF tops.
I use the clamps from Bangood on a hardwood bench and I reckon they would destroy the holes in an mdf top.
That is a valid question [member=44099]Cheese[/member] , and I believe you are right that they will eventually deform the dog holes which could create problems with dogs or other types of clamping systems.
Question, do a lot of you use your tables w/dogs as your primary way to cut? I ask because with the advent of rail squares and pgs to get square cuts are cnc quailty mft holes really necessary anymore. I use mine mainly for clamping and cross cutting and yes I know the ease in which the mft goes out of square,and dashboard has improve that. just curious.guy
Ya Bob, they will deform a small sector of the upper lip hole on the top side and they will also deform a small sector of the lower lip hole on the bottom side. For me that's "das macht nichts" as I use my MFT's as clamping platforms only.
I never really got into using holes & dogs as precision indexing systems because if you do the math...it will not be pretty, it's really catch as catch can. Sometimes it's accurate and sometimes it's not...that certainly doesn't work for me.  You're asking the impossible...there are way too many variables to get your arms around and control.
It also should be noted that Festool never intended that the MFT was to be used as an "absolute position" table to be used for precision cuts, but rather they offered it as a general assembly table that was convenient to use for on-site glue-ups and assembly. Thus the reason for the wildly different measurement variability when measured on state-of-the-art Woodpecker vision systems.
I have these Harbor Freight clamps.  By grinding off the cross-pin I can remove the clamping mechanism and slide the shaft through a MFG hole and then reattach the clamping mechanism.  These are light-duty clamps but have sufficient holding power to keep pieces from sliding around.  I bought them because they were too cheap to pass up at $2.00 each.  The H-F store is just 4 miles from my house and directly across from Starbucks and I wander through the store on occasion.
Note:  Mine are an older version and the small gripping end is not removable on mine.  It might be easier to drift the pin from that end rather than from the clamping end.
https://www.harborfreight.com/hand-tools/clamps-vises/4-in-ratcheting-bar-clampspreader-68974.html
Cheese has a good point here. Those who have set up (and may have used the Parf guide system or have a CNC drilled top) their MFT for critical cross cutting should consider these lever clamps carefully. I see that even a fresh top don’t necessarily hold dogs dead straight anyhow, not to mention what the well used holes might do.
I’m using it as an assembly, jig and clamping table. So I’ll probably buy a couple of these clamps.
Festool have released a limited set with these here, including some dogs, flat bars and those click clamps I don’t want.. in a systainer. Expensive though, most due to those click clamps. Bugger!
I’d like to add them new clamps to my old MFT Fix-set-in-a-systainer instead, keep it in one box, not two, otherwise I’ll be looking for what’s in the other box, which probably be out of reach..  [embarassed]
You don't have to grind those pins off. It's just a roll pin that can be pressed out easily.
As I recall the older version had a dimple to prevent the piece from sliding off.  It was a few years back.  I might be mistaken.  But note that if you get these, they are for simple hold-down purposes.  If you try to use these to pull a joint together the mechanism will strip.  It is probably just plastic gear teeth.  I ruined one, but I do use the others to hold down face frames while assembling using pocket screws.
Once set up, I can switch out the to-be-assembled pieces quickly.  It does require threading through the MFT holes and some may be a longish reach.  But for $2.00 each, they are worth having around.  I also have Festool clamps, but I prefer the trigger clamping method for face frames.
These clamps will be part of a MFT Set that will be available in the US next month. I got mine from Amazon.de with about a $15 shipping charge.
That's good to know...Sedge has been hinting that there will be a number of new products rolled out in March.
Do you happen to know the product number for the set?
