Rutabagared
- Jan 27, 2008
Sides and top book matched from 8/4 stock. Drawer fronts book matched from single board. Carcass assembled with 8x50 dominos. There is a bit of a color mismatch between the drawer fronts, carcass and base. Rather than go with the typical bracket-style feet I’ve done in the past, I experimented with a different type of base similar to ones I’ve made for display cases. Four coats of Target Coatings EM6000 satin production lacquer. I was able to apply all coats in about 4 hours due to favorable conditions.
[attachimg=2]
[attachimg=3]
The drawers are all NK style. A bit of extra work when constructing, but since the runner/bottom assembly is glued-up in it’s opening, they are incredibly easy to fit and operate super smoothly for years and years.
Drawer bottom/runners glued in situ
[attachimg=4]
Drawer box glued to bottom/runner assembly
[attachimg=5]
I wanted to spice up the typical know/pull applied to a flat surface so I made oval recesses for finger clearance behind what I planned on originally as rectangular drawer pulls (obviously, I ended up using round knobs from niceknobs.com, their Iconic Shaker 1-1/8) . The template was cut using the Shaper Origin. I used the Whiteside 1406B round nose bit with bearing. The bottoms of the recess required some hand sanding to remove the tiny ridges left from the routing.
[attachimg=6]
[attachimg=7]
[attachimg=8]
My Freud saw blade is dull and left saw marks on the end grain of the applied drawer faces. I’m always trying to apply hand tools when possible. In this project their application was limited to smoothing out these saw marks. I broke out the LN low angle jack and actually bothered to switch to the low angle spare blade I have for it. It was incredibly efficient at removing the saw marks, just a few swipes. A quick touch up with 400 grit and job done.
[attachimg=9]
[attachimg=10]
I’m still on the fence between an ash or walnut knob. Opinions?
[attachimg=11]
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
[attachimg=6]
[attachimg=7]
[attachimg=8]
[attachimg=9]
[attachimg=10]
[attachimg=11]
