HarveyWildes
- May 3, 2016
I'm wondering what the options are for attaching a non-Festool router to Festool track for straightline routing. The Festool options I know of are:
I like the idea of lightweight cordless routing outside and I'd like it to be as flexible as possible. A good solution would fit well to a Festool track, slide effortlessly without slop or torque on the track, and take advantage of the Festool stops. What other requirements would you add?
Any thoughts or ideas are appreciated
- The Festool Guide Rail base kit can be used with the OF 2200. I have the 2200 accessory kit, which includes it.
- There is a guide stop for the OF 1400 that does the same job. The OF 1400 also has the LR-32 plate, but can it be used without the LR 32 system??
- There does not appear to be an adapter for the MFK 700.
- Micro Fence makes an adapter (they call it an interface) for Festool track. A full package with the Micro Fence universal router plate, track interface, and the bars between them runs around $300. I already have a Micro Fence circle jig, so for me it would be about half of that.
- I'm not crazy about the idea of using the Micro Fence universal router plate with a Festool router. Has anyone tried it? If so, what did you think?
- I'd like an interface for my new Milwaukee cordless router, but I don't see a Micro Fence package that will fit a trim router. Has anyone tried it? If so, what did you think?
- There are some generic plates for other tracks that can be drilled for the router of your choice. Has anyone adapted these to Festool tracks with good success?
- Makita makes a guide rail adapter, but it looks like it will only fit routers with the same rod spacing as a Makita.
- Bosch also makes a guide rail adapter that I don't think is released yet. It does not show that it works with Festool track, and I can't tell from the bottom of the base whether it will or not. I also can't tell whether it will work with routers other than Bosch routers.
- There is a thread from 2018 that talks about a homemade jig, but it's not quite what I'm looking for.
