Attaching Systainer to CT26
MittensCat
I see in the manual that you either connect the systainer with the T-Loc or the four clips. If the T-Loc alone is used to hold the Systainer, it easily pulls away from the vacuum. The clip attachment points are positioned in a configuration that doesn't allow the the T Lock to be used in conjunction with the clips. Am I misunderstanding how this system is supposed to function? Thanks for any help.
  I have not had a problem with the T-Loc Systainer pulling away / off the vac. Are you making sure the T-Loc feet are under the lip before locking the T-Loc latch?
Thanks for the reply. You helped me figure it out. I didn't notice the feet opposite the T-Loc. This is my first time using a Systainer. I appreciate your help!
