Azek & Versatrek:PVC based products; read the fine print!
wotan
I have been using the pvc based products more often these days when replacing rotten sills and brick mould.  Recently I was working on a customers house when I decided to read the pamphlet  that was available with the product.  The manufacturer recommends that if you use the pvc product and you plan to paint it you should only use light colors, they highly recommend against  the use of dark colors on the Azek or Versatrek products. I called  one of the companies and was told that the product will absorb alot  of heat and possibly lift away from the screws or nails. So much for end all, be all!
Seems like all the box stores sell finger jointed brick mould, but only one company sold solid brick mould.
I was able to find Fir sills and White Pine brick mould , but am convinced that it is easier & cheaper to invest in a brick mould  bit and rout the pieces myself,when you need to paint dark colors on exterior window trim.
I am curious, What is the preferred wood for older(1800-1930's) exterior window trim?  Especially if the wood is properly primed and caulked!  I live and work in a couple of Historic neighborhoods.
It depends on the woods that were available at the time of construction in your area. You need to look that up.
In my area they still do not accept the Azek or Versatrek products if you want the home plaqued, at least not the last time I checked.
In our area it was Douglas Fir mostly.
Eastern White Pine and Redwood are also good choices for painted trim. Redwood is probably cheaper than EWP in clear grades.  Cedars probably will take and hold paint well as they are used for clapboards often.
I agree with just making your own higher quality moldings...
Best,
Todd
