YASMINSDAD
- May 24, 2012
Hi, major lurker. One of the first people in the UK to buy and promote Festool, I got my CT22 hand delivered by 'Mr Healy' when he was the sole UK supplier (now Elsons Tools)
One of the suggestions I passed on along with making the vacuum outlet central to facilitate ease of movement when pulling by the hose (yes shop workers site guys do this) was to remove the redundant sharp edge on the back wheels.
Many of us use the dust extractors to work on wood floors and the sharp raised wheel edge would sometimes leave tramlines in lacquer coats during intercoat sanding. The new CTL26, 36 and 48 came out with smooth wheels.
I just bought a CT15 to test it out before springing for a CT MIDI I and they have a pointless sharp ridge in the middle of the wheel.
This has already left marks in a sanded floor and would also potentially leave marks on a lightly oiled floor is used by painters etc.
This is a regressive step, the ridge offers zero benefit, I can only think the lower tolerances required on injection molding being a possible reason.
Did Festool not conduct any field tests at all with guys who sand floors? In the UK at least using CT vacuums when working on wood floors is very common.
I have 30k hrs experience at my job and probably 5 to 10k+ hrs on the CT vacuums, I connect my Lagler Flip edge sanders and Bona Flexidrive screeder to my vacuums and must vacuum up 500 to 1000kg of mainly wood dust every year.
Seems like poor design and little to no testing in the field. Other than that the CT15 is great, I mean apart from the lack of brake and proper hose depot to fit systainers (I am sure plenty of people would prefer a cheaper CT MIDI just without bluetooth and filter lever)
I am worried the marketing wankers are taking control, very worrying. I just replaced the brushes in my 2015 CTL36, other than that it has only had three lead changes, still on the original filter after several thousand kilos of dust. Filter lever seems like a gimmick, as does the led lights and 'touchscreen'. The clicky switch and potentiometer feel like they will last another 7 years, not sure I feel the same way about a plastic panel and some microswitches.
I also have around £6k worth of systainers, puzzled why Festool changed the height system, removed functionality by removing the side identification markers and added a pointless and expensive to manufacture handle for the BOTT system, which must be used by less than 1% of their customers. Seems like a poor engineering decision to add expensive features, like a handle that gets in the way and flaps about in certain pairings that most people will never use.
I appreciate the XXL versions, the new 'midi' versions and the increased strength, just seems like a very un German faux pas fitting an annoying feature no one wants and no one asked for (almost no one) and screwing up the height seems very foolish.
Why could they just not have added intermediate sizes? Many of us who go on site with dozens of systainers like to use them as trestles or tables, with or without bespoke MFT tops. Just seems more annoying now as the new Sys3 boxes infiltrate my stock.
Just my two pence worth.
