Bathroom storage solution
atomicmike
Last year (and a good part of the year before that), I remodeled my bathroom. Part of that involved moving the tub/shower to a more logical location to open up the room. Since the new location was about 6 feet long, that left me with the dilemma of spending several thousand dollars extra on a 6-foot tub, or using a standard 5-foot tub, and walling off the extra space. Not wanting to spend the extra money, and not wanting to completely waste the space, I came up with a solution...
[attachthumb=#] [attachthumb=#]
I can't actually take full credit for the idea; I saw something similar on an episode of This Old House a few years ago (can't remember which project it was, though). The rough opening for the storage was just under 9 inches, so there was not a whole lot of space to work with. I used 1/2" ply for the drawer boxes, and Blum undermount slides to try to maximize width. The accent lighting wasn't part of the original plan, but luckily I'd decided to add it early enough that I could still pull wiring in and add a light switch inside the lower cabinet.
Finding the right hardware to do the accent lighting was actually the hardest part of the project. Since the drawers are so small, heat was a big concern, making LEDs the only option. The other concern was finding a light that could still be recessed with such thin materials; the ones I found (Hera's Eye-LED) ended up being perfect, requiring only a 1" diameter by 1/2" deep recess. To hide the lighting, I ran it through grooves in the top and right side of the drawer box and hot-glued it into place. The top was then covered with a piece of 1/4" ply hot-glued into place to cover everything up.
The trickiest part of the hardware for me was a solution to keep the wires from getting caught up or damaged as the drawers slide in and out. I had originally planned on building some small articulated arms (much like are used on rack-mount servers for cable management), until I stumbled across some very small cable chains. I used a Domino sticking out of the back of each drawer to attach one end of the chain, with the other attached to cross-bracing below each set of drawer slides. The wire for the light slips easily into the chain, and the chain then clips to the two attachment points. Inside the cabinet, I ran the wire from each drawer down a groove in the side, which I covered up using a metal transition strip cut into small pieces. The lights all connect to a transformer in the bottom of the cabinet, which is plugged into a switched receptacle. I tried to make sure that all of the wiring and lights can be removed and replaced if needed without having to destroy anything.
[attachthumb=#] [attachthumb=#] [attachthumb=#]
The storage provided by the drawers has proved to be invaluable; I just wish I'd made them a little bit deeper to use more of the space behind the shower, but it's nothing I'm losing sleep over.  [wink] Feel free to ask any questions, or offer feedback or suggestions. This bathroom was my first remodeling and cabinetry project (and actually the reason I started buying Festools), so it was a fun and at times challenging experience.
For anyone interested in the chronicles of the rest of the remodel project, I made a series of blog posts as I went along: http://atomicmike.com/category/home-ownership/bathroom-remodel/. I still shudder when I look back at those photos of what the bathroom used to look like.  [scared]
- Mike
I love that cable chain solution u came up with,great thinking [cool]
That is a very creative use of otherwise wasted space! I am very impressed and if you don't mind I may "borrow" some of your ideas for use in my future projects. The Hera eye LED lighting is a very cool concept. Overall a fantastic job. My only minor constructive criticism would be to fill in the nail holes in your face frame - it kinda detracts from an otherwise spectacular project.
As a remodeling contractor I've dealt with that extra 1'+ of space many times of the years. I've come up with some pretty decent, creative solutions that made the client happy. However, I never came up with that great idea. Really awesome solution on that [thumbs up]. Great job. I think I'll have to join with others and 'borrow' that idea. Thanks for the post and pics.
I agree; they are actually filled in now, but I didn't even notice it in those photos until you pointed it out.  [embarassed]
Steve R said:
What was  your source for the cable chain?
The cable chain was from Igus; they call it Energy Chain. McMaster-Carr sells some as well, but I'm not sure if they have anything quite that small.
Thanks everyone for the kind words, and definitely feel free to use the idea yourselves!
- Mike
Great design! I accidentally showed the pics for my wife, so ELMO if your busy don't show them. Guess what's on her wishlist!! [big grin]
festoolviking
wow, what a great project!  i love the LED's!  where did you get them and how much do they cost?  looks very professional
Thanks for the compliment! I got the LEDs from Woodworker's Hardware (http://www.wwhardware.com/hera-eye-led-hleyeled/). They were a bit pricey at $70 per LED, plus $30 for the power supply, but I think they were well worth it. I've started just leaving them on 24/7 since they are so low-power, and they never get hot. They also make a very nice nightlight for the bathroom. :)
- Mike
So I've finally finished my version of Atomicmikes storage solution. Thanks for the idea Mike.
Mine got 2 doors and three drawers where 2 of the drawers got the "display slot" in the front. I haven't put any lights in and I'm not sure if I will.
It's made out of laminated chipboard and the fronts are made out of 19mm plywood. The festools used for this project: TS55, OF1010, Domino, OFK700 edge router, RO90 and the C12 for assembly.
[attachthumb=1]
Bathroom storage
[attachthumb=2]
Doors and drawers open
[attachthumb=3]
With items on display
Festoolviking
Nice! Love the illuminated easy-access display portion hiding the utilitarian drawers.
