the time has come for a bigger bed and I have decided to build it myself - never tackled a project of that size before, but well, there's always a first.
The actual bed will be approximately 220cm (86.5") by 180cm (70.8") featuring a headboard and two seperate mattresses. The final design is still WIP, with joinery questions being my primary concern at the time.
The attached image shows the joint between the stretchers (40mm by 150mm; 1.6x~6") and the front legs. I don't want to cut traditional M/T joinery (inexperienced, time constraints) and though of using dominos (10x50) as I have access to a DF500.
How many dominos would you use?
What orientation would you choose (vertical or horizontal dominos)?
As the bed needs to be collapsible, I need some sort of screws:
Would you rather choose hanger bolts or fasteners like the Maxifix 35 heavy duty ones (rated for the use in beds)?
Any input is greatly appreciated - updates will follow as time progresses.
PS: Please excuse the linguistic hiccups - I'm not a native speaker and not that used to English WW-vocab.
