This cabinet is made to fit the exact space at the side of my bed & i have also made it lower than normal, i find shop bought ones to tall. Mine is .660mm (26") wide x .540mm (21 1/2") high x .415mm (16 3/8") deep.
The carcase is made up of 18mm plain mdf glued to 16mm black walnut mdf to give a thickness of 34mm for a beefy look & solid feel. The bottom shelf is 18mm plain mdf with solid walnut edging to give the illusion of 34mm thick. It is fixed to the solid sides with 4 no 10 x 50 dominoes each side. There is no need for housing it in as there is no weight on the bottom shelf.
All the mdf was cut up with the ts55 on the 1.4m & .800 rails & every thing sanded with the rotex with 120 grit through to 320grit hand sanded with the grain.
The top is also double thickness with solid walnut edging all around. It is attached to the sides with the same amount of dominoes but it has also been housed in to a rebate. the top edging has been profiled to a slight curve on the spindle moulder & hand sanded with the same paper as the mdf.
The edging on the front of the sides is flat & 10mm thick.
