[attachurl=1]
A test fit of the back without the slats installed. In the legs the slots were cut with a 6mm bit with the domino 500 and then cut wider (7mm)on the router table for the side and back panels. The mortises were also cut with a 6mm bit on the widest setting to fasten the rails, made my own dominos for the rails 6mm x 29mm the mortises for the slats were cut with a 5mm bit.
[attachurl=2]
Test fit of back with no slats.
[attachurl=3]
Bench assembled.
[attachurl=4]
Bench completed.
[attachurl=2]
[attachurl=3]
Bench assembled.
[attachurl=4]
Bench completed.
