vkumar said:Hans what are the limitations of the Betterley product?
jarbroen said:p.s. I think those Betterley things are $150
Another step above that is to buy longer rails or switch to Mafell tracks and their joining system.
I've tried all of the above combos (including buying $400 long rails that weren't straight) and currently am very happy with the Mafell tracks. Of course, that means you can't use your TS55 or 75 and need a new saw... So not a cheap option, but ultimately much less frustration for me.
As [member=6237]deepcreek[/member] pointed out the Betterley is about $ 110, a whole lot cheaper than switching to a Mafell solution and still using shorter lengths of rail, and the TSO solution is even cheaper. I will stay with one of these options. Festool is pricey enough for me, forget about Mafell.jarbroen said:Anything that uses the Festool branded connectors will still be very fussy and prone to bumping out of straight.
The TSO connectors are definitely a step or two above the Festool version and alleviate the need for something like the Betterley 'checker'.
p.s. I think those Betterley things are $150. For that price you can get a pretty nice Stabila level which would be great to have if you ever do install/carpentry work.
