On our pool deck we've had a metal and glass pub height table for the past 10+ years, has served us well. With the addition of the Adirondack chairs and side table I built earlier this Summer, it was time for a matching Bistro table. The overall design came from a project plan in an old edition of Wood Magazine which I found online. The plan was priced higher than the entire back issue, and I remembered that a friend had given me a stack of woodworking magazines a few years ago. Yep, there it was - in my stash of magazines.
I changed the plans to make use of the Domino and changed the size of the table as well as the height. Wood, like the Adirondacks is Meranti. I was thinking that I should have resized the 4x4 legs to 2.5 x 2.5 as in the plans, but the overall size looks pretty good. It is darn heavy though with the 4x4 posts for legs.
Lots of measurements, made good use of all the Woodpecker tools. And it's amazing how well things go together when using the Domino. It's not quite finished but I figured I'd post this.
Some pics -
Parts cut and edges routed for the top -
Assembling the top -
Took advantage of the contrasting Meranti between 1x6s (light) and 1x4s -
Marking out the mortises on the legs -
Legs are Domino'd and assembled with a pocket screw -
Top resting on base -
And what it will look like with chairs -
What's left to do? Cleats need to be cut and attached to the base for mounting the table top. Then a final sanding with the RO90 and Teak oil finish needs to be applied. All in time to put it inside for the winter!
-Dom
Some pics -
-Dom
