Blade marks on 8/4 white oak with panther blade for TS75
ear3
New York, NY
I got the Panther rip blade specifically to cut some 8/4 white oak, but the results were not pleasing -- significant amount of blade chatter on the cut.  I had the saw speed set at 5 and DC hooked up.  This was the only thing I used the blade for, so it couldn't have been a dull blade.
Was wondering if there might be a technique or setting issue that I'm missing.
its normal, i get the same saw marks from that blade. less teeth faster rips + leaves marks but cuts smoothly and fast. more teeth smoother cuts but slower rips from my experiences.
Same here... Do you have an HL 850?  A quick pass is all it needs. Either that or switch blades and make an edge pass with the universal blade.
I ended up doing just that.  Maybe I'll post some pictures later, because the amount of dishing seemed abnormal to me.  But maybe that's life, in which case I think I'll just use the standard blade next time.
Thanks for the replies.
Not that I think it would change your results dramatically, but I would recommend running the saw at speed setting 6 unless cutting a material that will melt or burn, like plastic.
As others have said, there's a compromise when using a blade with fewer teeth: it cuts faster but the quality of cut is lower.
To echo others, you're better using the Universal blade for finish cuts. The Panther is meant to be used for ripping.
Just yesterday I used a Panther blade on my TS 55 to rip 7 foot long pieces of 5/4 white oak.  I'm building a door and I needed to get my 7" wide rough cut lumber down to about 5-1/2" so that I could handle them on a 6" jointer.  It wasn't a perfect cut, but it wasn't horrible either.  The track saw saved me from doing this on the table saw which would be a lot more dangerous.  A few quick passes of the cut edge over the jointer and all was perfect.  The Panther blade is perfect for this.  I have a rip blade for my table saw (Forrest I think) and it chatters on rips because its a narrow kerf.  I added a blade stiffner/damper and that helps, but I would never assume that I would produce a cut ready for glue up.  A few passes over the jointer is almost always needed.
Rip blades are great, but they are not the complete answer.
I don't mean to sound schoolmasterly, but have you tried with max. Depth of cut,i.e 75 mm?
