FestitaMakool said:I’m maybe a little late to chime in but, I have the Festool sander myself and recently an colleague bought this Bosch for sanding some outdoor benches (At this place there’s a few Bosch drills using the same battery, so..).
I had a chance to handle it briefly, no actual sanding though. At least I was curious and slipped on a battery and had a freehand spin.
Two things struck me right away:
It vibrates more, Festool’s are smother that way.
It’s back heavy with battery mounted. You need a firm grip and it could be tiring on a longer stretch.
Other things:
It’s very heavy by itself - maybe this is deliberate - to counterweight the battery.
Dust port on the side, upfront. I don’t know.. hose can be heavy and throw the balance of the tool. On the other hand: If you use two hands, you can support by holding the hose end too.
All in all, ETSC 125 is taller, but lighter and has much better balance in use.
It’s feels more refined too - so in this part of the world where these two sanders are closer price wise, I’d go with Festool.
Then, Metabo has released a trio of sanders on their 12V platform which seems interesting too.
They also are close to Festool in price. (€200 bare tool)
No just in time
I dont doubt that the Festool is better I was just impressed with the Bosch Gex over the Makitas and Dewalts. What battery did you use? In the video below he uses a 4Ah procore which seem to balance just nicely.
=100
Michael Kellough said:There can be no doubt that the Festool ETSC 125 is better and more refined than the Bosch GEX sanders.
If the Festool was only twice as costly as the Bosch I would have recommended it but in the States paying twice as much only gets the bare tool without a power supply, and the one that is required can only be used for Festool sanders. Even so, if a new sander is to be the OP's only sander for a while and if he expects to use it a lot I'd say get the Festool. I bought the little 12v Bosch as a supplement to replace hand sanding in awkward places from ladders. From heights I wouldn't want a Festool sander to fall.
Actually its the Bosch thats expensive here (Denmark) and not the Festool being cheap. The Bosch without any batteries is about 200$
