alfandel said:
			In this variation, full extension guides are used, exactly 350 mm.
Yes. I am about to make something similar.
Yours is:
  carcass - slide - MDFshelf/CNC - slide - carcass
This adds about 3 cm to the width of the "drawer".
My note is:
  carcass - slide - UprofileALU*) - plywood drawer bottom - UprofileALU - slide - carcass
That will add 6mm to the width for a SYS T-Loc for 430 inside carcass width, with a MAXI it allows the carcass to be only 610 mm inside as the sides taper.
*) 14*50*3mm ALU profile cut from a 50x30x3 rectangular profile, dust/FOD-protects the slides and forms the sides of the "drawer"
The point is to be as space-efficient as possible.
EDIT:
Truth be told, I came to this as do not have a big CNC on hand .. but the space efficiency was the main driver. I am even moving to SYS MAXI for most of my tool storage for the same reason - for shop-use-but-transportable they are more space efficient.
note:
When quoting here, try to remove the "inside" quotes if the post is big.
