Box miters with DF 700?
Len R
Is there a video or instructions on how to use the Domino 700 to join 45 degree box miters?  I'm joining 3/4" by 4" boards.  I have the Seneca cutter adapter so I can use the 4mm and 5 mm bits.  Thanks.
Good question.
I build a lot of boxes and have tried to use my 500 and 700 Domino with little success. I need perfect miters and have not been skilled enough with the Domino to get them.
Instead i use splines cut on my table saw. Perfect every time!
I have had success doing that with my 500 and the 4mm cutter. I had everything clamped tight and made a few sample cuts. I always use miter clips and sand the dominoes. Just my 2 cents.
Hope someone comes back with a good technique or reference video.  About the only thing I have not had success with using my DF 500  miters.
