(part 4 of 5)
2009, Nov 1:
I continued to make slow but steady progress on the arbour. The instructions and diagrams showed that somehow pieces of 3/4 inch dowel were involved with the post caps, but I could not determine exactly how the dowels were to be used. So, I came up with something that would work and utilized 1 inch dowel rather than 3/4 inch. I decided to drill a hole for the dowel into the top of the post then right through the cap and into the beam above it.
Here, 1 inch holes are being drilled through the centres of the parts that will be used to make the caps:
[attachthumb=#1]
Using a small piece of 4/4 wrapped with a few layers of masking tape in order to simulate a post with a loose fitting cap, I hammered trim into the bottom of the caps:
[attachthumb=#2] [attachthumb=#3]
Next, I screwed the cap tops into position:
[attachthumb=#4]
Unfortunately, I nailed the trim to the wrong side of one of the caps. This gave me the opportunity to make use of a small cat's paw that I have been carrying around in my main tool box for at least a couple of years:
[attachthumb=#5]
This is the first time I have ever used the tool, but it sure came in handy when I needed it. I managed to salvage both the wood and the nails. The cat's paw pulled the nails right through the so, when re-applying the trim (this time to the correct side of the cap piece), I had to use screws.
[attachthumb=#6]
The next task was to cut all the posts to a uniform level. The instructions suggested that I might want to use a circular saw to to do this job. I don't want to use a circular saw when standing on a ladder, so that was out. The alternative offered in the instructions was a hand saw and that would have worked. But, I guess that whoever wrote the instructions had never heard of either a Festool or Bosch jig saw with long, wide, strong, and guided blades. I first scored each post on all 4 sides then cut all the way through. The results were very good!
[attachthumb=#7]
Next, the screens were attached. I want them to be easily removable. The instructions claim that they are, but I could not figure out how they managed this in spite of looking very closely at all the drawing and the pictures. So, I screwed 2 small blocks to the bottom spline, then I attached the bottom of the screen to the bottom cross rail with screws through the two blocks. Two more screws, through the top cross rail into the top spline, completed the job.
[attachthumb=#8] [attachthumb=#9]
Using a partly completed cap as a guide template, 5 centimetre deep 1 inch diameter holes were drilled into the tops of all the posts. Then, the completed caps were placed on top of all the posts with the dowel extending up above the cap about 5 centimetres.
[attachthumb=#10] [attachthumb=#11]
Four beams, four braces, and six rafter pieces were cut with a jig sawafter transferring the full size fancy end patterns to the wood using tracing paper:
[attachthumb=#12]
I made a small drilling jig then used it to drill holes to accept the dowels into the bottoms of two of the beams:
[attachthumb=#13]
Six centimetre deep 42 millimetre wide notches were cut into the top of these two beams just above the position of the posts. I had previously milled all the lumber to be used for the beams, rafters, and braces to 40 millimetres so this left 2 millimetres of play with each notch. Here two beams are in place on the posts and the other two beams are being checked for position in the notches.
[attachthumb=#14]
