Blackberry said:Building Kitchen Cabinets by Udo Schmidt - Tauton Press
Furniture & Cabinet Construction by Andy Rae - Tauton Press
Both are good books.
jeep jake said:How are you guys joining your cases? I was going to Rabbit everything, and join it with glue and nails. I was thinking about useing A1 3/4 plywood. Mounting them with cleats, using venear edgebanding, to cover the core. Also I was going to just use a sheet of plywood for the face with edgebanding, no frame at all. What do you guys think do you think it would be a quailty product. Do you think there would be any movement? I've been a carpenter for the last decade, just never had a opportunity to build cabinets. Also I was going to use the surfix oil kit for the the finish, probally the one step?
Brice Burrell said:jeep jake said:How are you guys joining your cases? I was going to Rabbit everything, and join it with glue and nails. I was thinking about useing A1 3/4 plywood. Mounting them with cleats, using venear edgebanding, to cover the core. Also I was going to just use a sheet of plywood for the face with edgebanding, no frame at all. What do you guys think do you think it would be a quailty product. Do you think there would be any movement? I've been a carpenter for the last decade, just never had a opportunity to build cabinets. Also I was going to use the surfix oil kit for the the finish, probally the one step?
Save yourself a lot of trouble and get prefinished plywood.
jeep jake said:I am not to worried about the finish I have uses the surfix oil kit on a couple 100 square feet worth of shelving I have never done maple only cherry but I doubt it will be much different if it is let me know. All the per finished maple I have seen has a really high gloss finish and it's not my thing.
jeep jake said:I don't own a domino that's why I was going to do rabbits
