Mike Goetzke
- Jul 12, 2008
I've had a cordless Makita track saw since middle of last year. I just picked up a TS75 for my deeper cuts. I saw in the TS55 supplemental manual a method to adjust two Festool saws to single track but here is what I found when trying to adjust the Makita to the TS75.
The Makita has four screws on the bottom. I loosened these and adjusted the base to match the blade position on the TS75. I needed to move the blade further from rail rib.
No big deal but I had a brand new anti-chip on a new Makita rail and the saw barely cut into the anti-chip. Guess as long as it cut I'm fine but just curious why the blades weren't positioned closer out of the box.
Is there a specification with tolerance for the TS75 blade to track rib dimension?
Mike
Mike
