Two coupled 55" guide rails is 110" or 2" longer than the 108"/2700mm rail. Either arrangement is just long enough to make 8' rips using a TS55, but slightly too short to do the same using a TS75.
It does take 2 of the Festool rail couplers, cat 482 107. You would expect those to be stocked by B&M dealers selling TS saws and MFT/3, but these days double check to be certain.
If you are planning to couple LR32 "Holy" rails, you also need set of LR32 Guide Rail Connector (cat 496 938). Despite the name these only establish the 32mm spacing of the connected holes. You still need 2 of the cat 482 107 Guide Rail Connectors.
Please note that for some reason the Guide Rail Connectors are sold individually, so you need to purchase at least 2 of the cat 482 107 to accomplish anything.
Meanwhile the LR32 Guide Rail Connector, cat 496 938, are priced as a set of 2. Go figure, because to establish the hole spacing you only need one of the cat 496 938. However, those are also used as limit stops to position the bottom hole correctly from the bottom edge of cabinet sides. Many people use such a stop at either end. Apparently when Festool introduced the more sophisticated cat 496 938, they realized they belong as a pair. The previous LR32 limit stops were sold as a unit of one. This is the sort of thing which causes confusion!
