- Feb 22, 2016
TylerC said:The CT SYS is a little different than the others in this regard. First, all the other CT vacuums do have bypass cooling, which is essentially a secondary fan that pulls air through the motor area, which keeps the vacuum cool if it were to clog.
In the case of the CT SYS, there is a slightly different set-up. If the hose becomes clogged, a bypass valve will open. You can actually hear it. This still provides the protection from overheating, it is just a different design than the standard CT.
The bypass valve is something the central vac system in the house has, and I have often thought I should add it to my dust collection system in the shop. For the house vac it's great because it prevents those times where your vacuum latches on to something like a drape or piece of cloth and it seems the only way you can free it up is to shut the vac off. The bypass valve is adjustable.
I bring this up because I have used my whole house central vac with a Dust Deputy when working around the house in place of removing the CT36 from the shop and dragging it around with me. The house vac has plenty of power, is a HEPA vac, and is located in the garage so all the noise is outside the house. I made up some adapters so I can run just about any handheld power tool I have off this setup, including my DeWalt cordless mitersaw and DeWalt track saw before I got the TSC55. No sawdust makes it out to the vacuum dust bin, it's all captured in the Dust Deputy's 5 gallon bucket.
