threesixright
- Aug 17, 2017
Hi All,
I need to cut a ventilation hole in a piece of plywood (200 mm diameter). Seems like a great opportunity to use the Carvex (PS 420) circle cutter.
Dumb as I may be. What is the smart way to start the hole?
a) Pre dill a (forstner?) hole against the circle and then use the cutter? The cutter attachment is pretty rigid.
b) Doing it with a plunge cut? [blink]
c) Something better?
Checked out a few videos, but what I found, cuts where made from the "outside" of the workpiece.
I'm sure sone of you smart fellas already got did covered [big grin]
Some help appreciated, thanks!
