SticksInTheMud
- Mar 16, 2014
I tried to use my Carvex circle cutter for the first time, when I almost immediately ran into a problem. As you can see by the attached photos, shortly after beginning the cut everything went wonky. The metal tape of the device buckled, but I don't know whether the device was pulling the blade off track, or vice versa. I tried cutting in the opposite direction and got the same result. It was far enough off track that the blade bent. I eventually used the device with a pencil to draw a circle and freehanded the cut (with a new blade) and everything went fine (I sanded to the line). Where did I go wrong?
