CARVEX! Pics and Vids – Launching Sept. 1, 2013
K119Phil
Please call 650.588.0160 to place your orders!
Free Shipping!  (To be released on Sept. 1st)
New Products – Launching September 1, 2013
The CARVEX Jigsaws – More than you ever expected from a jigsaw
Launching September 1, the robust and versatile new Carvex Jigsaws will exceed every expectation your customers have for what a jigsaw can do.  Featuring seven different baseplates for cutting wood, wood-like materials, plastics, and metals, the revolutionary new Carvex Jigsaws will adapt to the most challenging tasks.
Precision.
With 3-point blade guidance, 4 stroboscopic LED lights, and zero-clearance Splinterguards, the Carvex delivers cuts that are straight and true, with virtually zero tearout!
Versatile.
A revolutionary tool-less base change system delivers the most versatile, adaptable jigsaw cutting system your customers have ever experienced.
Durable Brushless motors and a robust design ensure that the Carvex can handle not only the toughest materials, but the toughest conditions as well.
For a complete introduction, check out the brand new Carvex video intro here:
Please note: Launch date for Cordless Carvex models is TBD. Corded versions only are launching September 1.
PS 420 EBQ Barrel Grip Jigsaw
Launch: September 1, 2013
Item No.: 561 593
Price: $350.00
PS 420 EBQ D-Handle Jigsaw
Item No.: 561 608
Price: $350.00
Weir Masterworks shared a project using Festool jigsaws
New Festool Carvex 420 by Festool USA
New Festool Carvex Accessory Kit by Festool USA
More details to follow!
Base System.
The new Festool Carvex 420 jigsaws have six different application-specific tool-free swappable bases and base plates. One of the most noteable is the angle base. The dual beveling angle base allows you to make inside or outside angle cuts which increased precision and stability.
The angle base has two beveling feet that provide greater stability and accuracy when making inside or outside angle cuts. A steel base plate is available for metal-cutting applications. A guide rail adapter base gives you the ability to use Festool guide rails for straight, accurate cuts and also serves as the base for attaching the circle and radius cutting accessory. Use the hook-and-loop base plate with replaceable felts to prevent scratches on delicate materials. A dimpled base plate is available for uneven surfaces and is low-friction. The hard fiber base plate has an ultra-smooth surface with low friction.
For your best value, consider the Carvex Accessory Kit, which contains all of these bases as well as other accessories in a Systainer for organization.
Cut Line Visibility.
The new Carvex 420 jigsaws were designed to ensure high visibility of the blade and cut line. After all, your cut is only as good as your ability to see what you're cutting, right?
We started with four high-intensity LED lights that are stroboscopic, meaning that they pulse in unison with the blade. That strobe effect makes the blade appear to stand still as you cut making it easier to stay on course. The LEDs provide great visibility even in low-light conditions. The LEDs can be configured in three modes: always on, always off or stroboscopic.
The adjustable dust guard can be slid up or down to maximize visibility while ensuring effective dust collection.
Speaking of dust collection, Festool's reputation for great dust extraction means you won't have sawdust covering your cut line.
Splinter-Free Cuts.
When working with expensive materials like cabinet grade veneered plywood or MDF, it is important to have cuts that leave splinter-free edges to eliminate re-work or to minimize the amount of time spent cleaning up the cut.
Festool Trion and Carvex jigsaws have an innovative replaceable splinterguard that acts as a zero clearance for the blade. The splinterguard prevents tearing and chipping, leaving you with crisp, clean cuts. Splinterguards are made from clear plastic, so your cut line is unobstructed. The splinterguard simply slides into the base of the jigsaw without the need for tools or adjustments.
Festool's MMC electronics and a variable speed setting will ensure that a consistent and appropriate blade speed is used for the material being cut. MMC also protects the jigsaw from overheating and overload scenarios.
Perpendicular Cuts.
You've probably experienced less-than-square cuts with a jigsaw before. Well, that's a thing of the past with Festool Trion and Carvex jigsaws.
Festool's triple blade guidance system ensures that the blade stays perfectly perpendicular, even when cutting materials up to 4-3/4" in thickness. The guidance system prevents blade deflection and results in cleaner cut quality.
