I forgot to mention something that I found out at a Roadshow event.
The knobs that hold on the green splinter guards that mount on the TS55-REQ and the TS55-EQ look similar and are of the same diameter. If you accidentally grab one that belonged with the TS55-EQ and accidentally insert it into the TS55-REQ it will thread and you will think that everything is ok until you start your saw and plunge. The old screws are longer and your blade will make contact.
Just wanted to pass this on.
