CE Countersink dr. bit 4.5mm - 492524
harry_
I am looking for the part number for the replacement bit for:
http://www.festoolusa.com/power-tool-accessories/cordless-drills/centrotec-drill-bits/pilot-bit-with-depth-stop/ce-countersink-dr-bit-35mm-492523
http://www.festoolusa.com/power-too...-depth-stop/ce-countersink-dr-bit-35mm-492524
I have a pack of replacements bits which are almost exhausted which have the part number of 494 446. However this part does not show up when searching the Festool website.
Festool should add/update this info to the above link as there is confusion:
In the bulleted ares of the description is says 3.5mm instead of 4.5mm.
[edit]
I had originally mis-pasted info stating 3.5 mm
What I need is 4.5 mm
DougB,
Thanks for the reply. You are correct according to the info given, which was incorrect. I have corrected it.
The part number for what I have is correct though 494 446, which is for 4.5mm bits (set of 5).
Update:
Called Festool service:
The part number I have is valid (494 446). It just doesn't seem to appear anywhere, either at Festool's website or the sites of those dealers that I have checked so far...
Have sent an email to my preferred dealer to see what's up
