Folks -
I want to try to center some 4mm tenons in 11 mm thick stock. However, the fence on my 500 will not come all the way down at 90 degrees. Any angle much less than that, and the fence comes all the way down. I saw the half-inch shy page on filing off a corner, but my fence is the newer type and is shaped differently.
I realize I can reference off the base and raise the workpiece a bit, or attach a shim to the fence, but I'm wondering if there is a more elegant solution. After all, Festool made 4mm tenons which are the right size for 12 mm thick workpieces, and I'm guessing that most times folks reference off their fence at 90 degrees, so why make the fence so you can't center these little tenons?
So, how do folks center their tenons in thin stock? And, if you use shims or raising the workpiece, details on how best to do that would be appreciated. Thanks,
Ken
Ken
