Ivan T
- Jan 21, 2010
When changing cutters on the DF 500 it is sometimes awarkward to hold the Domino and turn the cutter with the supplied wrench. I have seen on FOG someone had a jig that held the domino while changing the cutter. Looking over the DF 500 I see the bottom is mostly flat. I layed the DF 500 on the MFT 3 and used a clamp to hold the Domino as I used the wrench to change the cutter. DO NOT OVERTIGHTEN THE CLAMP. The clamp worked just as well on a piece of 1 by 4 also. See attached pictures.
This made the task easier.
