Cheap Festool Granat Abrasives. HSK handsanding 80mm x 400mm + others
scbucc
Anyone looking for cheap Granat abrasives for hand sanding? or, happen to need Abrasives for their LEX 185, LEX 77, or LRS 400?
I have Granat LRS 400, 80mm x 400mm Abrasives available.  These fit any of the HSK sanding blocks.: 40, 60, 80, 120, 150, 180, 240, 280, and 320 grit.  At least 10 boxes of each grit.  The 80mm x 400mm abrasives are perforated down the middle so they tear to make up 80mm x 200mm.
I no longer have a the Long board LRS 400, but these abrasive work perfectly with Festool's 80mm x 200mm hand sanding block, and the 80mm x 400mm hand sanding block.  Also, they can be cut to length to accommodate the smaller 80mm x 130mm hand sanding block. 50 per box at 80mm x 400mm, 100 per box at 80mm x 200mm (I use the 80x200 sanding block most often)
Festool LEX 185 Abrasives 80 And 180 Grit, Anyone for 7" sanding discs?  I have at least 10 boxes of 80 grit and 180 grit
the 80 grit has 50 per box, and the 180 grit has 100 per box
Festool LEX 77 Abrasives:  80,120,150,180,240,280,320,400,500, and 1500 grit. 50 per box.  I have at least 10 boxes per grit.  77mm sized sanding discs.  Just over 3".
If anyone is interested let me know.  I can post some pictures if need be.  These are all unopened boxes.  Great for Hand sanding, if nothing else.  Will sell cheap enough to make them the ideal hand sanding option.
Thanks,
Steve
