Bert Vanderveen said:This may not apply to your country, but over here in the Netherlands big stores that service pro’s sometimes have clearance sales and offer original Festool accessories with nice discounts (they call it an ‘inventory clearance’). Recently I bought a couple of Domino cutters at half price.
Birdhunter said:My experience with Amana router bits has been positive. The blurb says the bits are solid carbide. However, the picture looks like the tip is braised onto the shaft as is the bit from Festool.
I don't think this a negative as a solid carbide bit would be more brittle than a tool steel bit and probably more expensive.
Birdhunter said:I am a heavy Domino user although far from being a professional. I've cut thousands of Domino mortises over many years. I seem to remember having broken the original 5mm Festool cutter cutting into end grain oak. I have broken a 4mm cutter as well, but no others. All my Festool cutters produce tight mortises.
I look at the cutter price as how many holes per dollar and the Festool price seems more reasonable. I also know that my Festool dealer would replace a cutter that suffered infant mortality (like in the first dozen holes).
yetihunter said:Hartville sells Whiteside bits. Use coupon code: WN15 at checkout.
I used to only have Whiteside bits early on. They cut great. My only issue is that when I left my router bits stored for a year, Whiteside was the only make that developed rust on the shanks.
Freud, Amana, Leitz/Festo, CMT, Lee Valley were all fine. You can also buy Whiteside rebranded from Klingspor Woodworking shop and Eagle America (prices are generally the same).
For the Domino cutters, there are a lot of offerings in Germany but I don’t live in Europe so I never kept track of who, what and where. As already mentioned, in North America, you can get Amana (no real feedback but probably great) and CMT (mostly only poor feedback). I remember there’s an error in one of Amanda’s domino cutter lengths in either their catalog or spec sheet that gets repeated at retailers but you can likely deduce which ones are for the 500 vs the 700 based on the way their grouped on the chart.
Mario Turcot said:Birdhunter said:My experience with Amana router bits has been positive. The blurb says the bits are solid carbide. However, the picture looks like the tip is braised onto the shaft as is the bit from Festool.
I agree, you never know unless you have one in hand. I bought a replacement bit for the LR32 kit, the bit is identical to the Festool one beside the name printed on it.
Amana Tools is my favorite brand. Would like to try out some WhiteSide bits but each time I look for one specific, they are out of price. Often double $$ compare to Amana Tools bits. Infinity tools also provide some specialty bits I like, like the flush trim double bearing bits.
Spandex said:Surely you don’t only ever use Festool drill bits, or router bits?
But regardless, without knowing if the Trend bits are better or worse than the Festool bits, how can you know which one would be classed as ‘skimping’?
Spandex said:So you would spend £6 more on bits even if they were identical in function and reliability? Each to their own, I guess.
