ear3
- Jul 24, 2014
I just realized that I have to raise the angle on my Narex bench chisels if I want to do anything other than paring. Rolled the edge on several chisels, which are all currently sharpened at 25 degrees primary bevel (with a Veritas MKII induced microbevel), while I was squaring the corner in a 1/2" deep rabbet in white oak.
I'm just trying to figure out now whether I should raise the angle on all the chisels to 30 degrees or more, or whether it might make sense to get a second set of chisels so that I have one for chopping mortises and other tasks that involve working against end grain, and another reserved for paring and shaving work that I would keep at 25 degrees.
Just curious -- for those of you who keep your chisels at a more obtuse angle (30 degrees+), do you shape the whole primary bevel at that angle, or just a smaller secondary bevel? If the latter, how much of the blade do you have to sharpen at the higher angle for it to be effective (1/16"? 1/8"? more?)
If I get another set of chisels, I will probably go for something better than the Narex. Do you think it's better to have the higher end chisels for paring work or for chopping mortises and other heavy duty action?
