HarveyWildes
- May 3, 2016
I've been kind of promising myself an 18" triangle, but I've been waiting for Woodpeckers to do their OTT triangle to make a choice between TSO and Woodpeckers.
Here are my current thoughts on the available triangles:
* All are advertised to have .001" accuracy.
* Lifetime Replacement for Woodpeckers, did not see a comment on the TSO site regarding lifetime replacement.
* Dual scales - TSO has both metric and imperial scales on one triangle, Woodpeckers has one or the other.
* MFT compatibility - TSO has 20mm holes and 96mm spacing to work with MFT tables, Woodpeckers does not.
* TSO MTR can handle arbitrary angles, TSO PTR and Woodpeckers are geared to 90 and 45 degree angles.
* Cost: Woodpeckers ~$200, TSO PTR ~$200, TSO MTR $250, TSO MTR kit $380-$400.
The Woodpeckers triangle vs the TSO PTR are at rough parity, but I'd give the TSO triangle a slight edge based on the dual scales and the MFT compatibility. I have to admit that I'm tempted by the TSO MTR - perhaps just getting the basic triangle to start with and adding the kit later. Seems like that would give me any angle of cut without using the MFT protractor.
So here are some questions for people who have used them:
* What am I missing that should be part of deciding which triangle?
* Do people who have the MTR find that it is actually useful to be able to set arbitrary angles?
* Do people who have the MTR kit find the clamping angles useful?
