Chuck stuck halfway off
Dreaume
The chuck on my drill came half off and is now stuck in that position. I can't remove it or fully attach it no matter how hard I pull or push. If it helps diagnose the problem, the bit spins when power is applied, but with no force... I can stop it from rotating by pinching it.  Any suggestions would be much appreciated.  I was really hoping to build stuff during the upcoming quarantine!
Thank you.
Spray with WD40 and then gently tap with a hammer. If that doesn't work, not so gently tap it with a hammer. Then it's time to drop it from at least the 3rd floor. Beyond that, explosives. C4's guaranteed to work.  Please report back.
