Hello all
Like a lot of us I’ve had a few home made circle cutting jigs in my 40 yrs of woodworking. I now have an urge to make a universal one that would work with all of my routers. I currently use a .250 plywood one that works but I’m not crazy about it.
I’m thinking about using long drill rods 5/16” Since Festool doesn’t make a universal fence for their routers I’m thinking of using the Guide Stop as the pivot point. Using a longer 8mm bolt in the knob and then using a Parf Dog as the center point. Each router has Guide Stops so it would be a matter of changing the drill rods from say the 1400 to the OF 1010. This way I could swing circles in any diameter. I do have concerns about when the radius starts getting larger than say 24” that the rods may flex. I could make stabilizer that slide on that have set screws.
I thought I saw a post a long time ago about someone who designed something similar using the Guide Stop as the pivot point
Looking for suggestions on something universal and stong. I want to get away from the plywood. I did think about using an aluminum plate but I think I want to pursue the drill rods and Parf Dogs unless there have been negative results that someone has experienced
Thank you all for taking the time to consider this
